Paycheck matching problems - No help in Quicken Help
Quicken Community
Employee mod
My paycheck sometimes changes. So, I end up with the automatic entry I set up with splits and the downloaded transaction that doesn't match. For a long time I couldn't figure out how to fix this without voiding one or the other. The Quicken Help doesn't cover this topic!!! I finally figured out how to do it. Edit the split. Then change the downloaded transaction to uncleared. Then click the icon in the first column of the paycheck with splits. Tell it to match the transaction and you are done.
What are you suggesting? That a help topic covering matching femonders to downloaded transactions be added to Quicken?
Quicken Help is not very helpful. I hope the new owners put some effort into improving it.0
Ok so you're suggesting that a help topic be added.
Questions? Check out the Quicken Windows FAQ list0
