Wells Fargo Login Problem In Web and Mobile Applications (Direct Connect)
When using the Web Application (and Mobile also), I continue to have problems logging into my Wells Fargo accounts via Direct Connect. This has been a problem with the mobile app since the major upgrade. My desktop works fine and the old mobile app works also..
When I click on the red exclamation point next to my Wells Fargo accounts on the new web app, I get a pop-up with the following message...
Quicken for Windows Premier on Windows 10
Year:2019 - Version R14.23 - Build 27.1.14.23
All my other accounts work fine
Thanks....
This account needs your attention We are unable to connect to Wells Fargo at this time. Care Code: ccscrape.181My desktop version is
Thanks....
https://getsatisfaction.com/quickencommunity/topics/mobile-and-now-web-not-able-to-connect-to-regions-bank-to-update
Intuit's generated unique Ids have the problem that they are based on some "seed" that changes if you reset or deactivate/reactive.
If you are using Direct Connect you shouldn't have this problem.
Note this FAQ has a procedure in it for finding and deleting these duplicate downloaded transactions.
https://getsatisfaction.com/quickencommunity/topics/faq-i-have-a-manual-account-i-want-to-activate-for-downloading-how-do-i-prevent-duplicate-transactions
https://getsatisfaction.com/quickencommunity/topics/please-be-aware-third-party-support-companies
The only place to reach FREE Quicken support is via chat or phone here:
https://www.quicken.com/contact-support
There are also 2 more official Quicken #'s:
Though they no longer publish it, the same old toll-free number they have always had is still valid for non-premium memberships: 1-888-311-7276
For premium memberships, you have to look up the number in your Quicken.com account. This will give you front-of-the-line service (using same reps).
(If you find this reply helpful, please be sure to click "Like", so others will know, thanks.)
(QM2007, Canadian user since '92)
Have Questions? Check out these FAQs:
If this were a full replacement for the desktop version, rather than a supplement to it, it would be a different story. As it stands, when I'm in the grocery store, I open the app as I near the register, and then start to enter the transaction except for the amount. Then the window pops up that says "Wells Fargo Enter your credentials", which takes several seconds to dismiss, and just kinda irritates me every time I check out.
I continue to have issues with Mobile and Web Connections with Wells Fargo...this morning I had both Mobile and Web working with no Care Code: ccscrape.181 but this afternoon the issue is back...since there is no phone support and the session with Chat Support gave up on me last night I do not know how to resolve...Please Help!
I am using Quicken 2019 and have tried to use the new Quicken Web feature, but my Wells Fargo accounts are not recognized and won't update. I keep getting the message "We are unable to connect to Wells Fargo at this time." It lists a Care Code number that varies but the last one was 323. It give an option to Retry, but the same thing keeps happening. I also have a connection problem with my Credit Union of Texas account. All other accounts seem fine. All these accounts update and sync correctly from my Quicken desktop. Help please.
Within Quicken, I would reset your cloud and try to sync again to see if the issue exists:
Mac: https://www.quicken.com/support/how-edit-or-delete-your-cloud-datasets-quicken-mac
Windows: https://www.quicken.com/support/how-edit-or-delete-your-cloud-datasets-quicken-windows
Please let us know once this is completed and let us know if the issue exists.
Respectfully,
~ Quicken Harold.
Community Moderator
I will send this thread up the chain..
We deeply apologize for the inconvenience that this has caused.
Respectfully,
~ Quicken Harold.
Community Moderator
Also, why does the cloud need my bank passwords ? I am just sending my desktop data to the could when I sync. Why in the world is it necessary for the cloud to sync with the bank as well. I wish I could turn that off. It is pointless.
