Quicken Community is moving to Single Sign On! Starting 1/22/21, you'll sign in to the community with your Quicken ID. For more information: http://bit.ly/CommunitySSO
I'm at 2015 home and business. If I upgrade to 2020? will my problem with compatible files go away
Randall McCaffry
Member ✭✭
All my banks offer a download files (for quicken) in QXF format. Quicken seems like it is supposed to import such format but never recognizes such files. Is this a problem of the version I have or something else. If I upgrade will it fix this
Best Answer
Quicken does not force anyone to do anything, and it is not every year either. You can use the software manually after it expires (except the Starter version, which renders data read-only). And there are subscriptions available for up to 27 months (24 from Quicken and 27 from third parties). The only thing that has changed is that the time frame allowed for online/download functionality down from about 3 yrs previously.
Also, it does not have to be that expensive. Quicken just had a 40% off sale, which they have done on and off several times. Third parties often sell the product at a 33%+ discount. You can always shop around.
As for quality, well that is a different topic.
FYI, in case you did not know, Quicken is no longer owned by Intuit.Have Questions? Check out these FAQs (links now fixed):- Where to find a Help Guide for Quicken for Mac?
- Quicken Mac FAQ list
- Quicken Windows FAQ list
- Help Guide and FAQs for Quicken Mobile
Object to Quicken's business model, using up 25% of your screen? Add your vote here:
Quicken should eliminate the LARGE Ad space when a subscription expires
(Canadianuser since '92, STILL using QM2007)
5
Is that actually supposed to be QFX format? Because QXF isn't what the banks download.And, you can't download now because Q2015 was discontinued on 4/30/2018.See this for further explanation: https://community.quicken.com/discussion/comment/19399394#Comment_19399394
Q user since DOS version 5
Now running Quicken Windows Subscription, Home & Business
So, I think I understand. Q forces users to renew every year by not just reducing access or denying support, but removing functionality. There is a date sensitive command built into the software. That is their right, it is their company. Evaluating, I must spend $200 a year with Q and TT. Frustrating as Q had holes, short comings in tax assignments, etc. If they spent as much time improving their product as they do manipulating the market, it would be the best product ever. Next year, it will be the same amount of work, H & R Block and spreadsheets. I don't like being the prey when they are the predators. This year it's $200 and will only go up.0
5
