Quicken will not act normally, how will I fix these issues?
First: will not save new transactions. Second: downloaded matched transactions accepted, new transactions are not accepted. Subsequently, restored to a point five days ago, can save new transactions. Then downloaded transactions, accounts were red flagged but, no downloaded transactions listed to to accept! Tried to download Quicken Premier from my account at Quicken.com got message, "The contents of this file cannot be unpacked. The executable you are attempting to run has been corrupted . Please obtain another copy of the file, verify it's integrity, and try again." What are my options? Working with Windows 10 Home Version 10.0.17763 Build 17763
  • Greg_the_Geek
    Greg_the_Geek SuperUser, Windows Beta ✭✭✭✭✭
    What is the full path to the folder that contains your Quicken data file on the hard drive? Do you have Controlled Folder Access enabled in Windows Defender? Are you using OneDrive, Dropbox or Google Backup?
    Quicken Subscription HBRP - Windows 10
