Please reopen Problem with Quicken will not connect to SunTrust Bank Accounts {"Ticket ID":"766806
TomInMiami
Member ✭✭
Problem with Quicken will not connect to SunTrust Bank Accounts {"Ticket ID":"7668064"}
This problem is still not fixed. The thread contains a workaround that someone can use to get around the problem.
Quicken user from 1988 currently running on both PC and Mac to evaluate when to migrate to MAC. To me MAC version is not quite there.
Hello @TomInMiami
Thank you for reaching out to the Community regarding your issue, though I am sorry to hear that you are still having issues. If you are still having issues with Suntrust I would recommend contacting support as they're able to investigate further to find out what's causing the issue you're having. We don't have the same ability to do so on the community as phones do when it comes to escalation issues. I do apologize for any inconvenience this has caused.
Thanks,
Quicken Francisco
