When I save a report and then try to retrieve it using the "My Saved Reports Reports and Graphs" pull down menu, the correct Report does not populate=—I get a random report from a different year and different Tag. For example, I recently created a report for November 2023 Spending on a particular property. When I go to see that saved report, Quicken populates a report for 2016 for a totally different property. This does NOT happen if I use the "Reports and Graphs Center".
[Although I've noticed that at times when using the Reprots and Graphs pulldown, I'm sure I've saved a Report and when I go to see it under the Reports and Graphs Center" I get a report for the correct property but it populates the last month, rather than for the time period I thought I had saved. This may be because I didn't properly save the Report]
I've been using Quicken for over 20 years and this problem with the "Saved Reports and Graphs" menu just started to happen in the last few years.
Any ideas on why this is happening and a fix for the issue?
