Community Homepage
Discussions
Quicken for Mac
Quicken Lifehub
Quicken Mobile
Quicken on the Web
Quicken for Windows
Support
Quicken Classic
Quicken Simplifi
Getting Started
Community Training FAQs
Using and Improving the Community
Connect and Engage
Announcements & Alerts
Announcements
Alerts, Online Banking & Known Product Issues
Product Ideas
Beta
Home
Quicken Classic for Windows
Investing (Windows)
Problems with opening balance after Truist conversion
gawws
My SunTrust checking accounts refused to update when SunTrust switched to the new Truist website. I deactivated the accounts and added back online services using Truist as the bank. It appears that process changed my opening balance. This has happened across all the SunTrust accounts. Do I have any recourse beyond a restore from backup or an "Opening Balance Adjustment". The account is too old for rekeying data to be an option and the checking account routinely transfers to investment accounts.
Find more posts tagged with
Accepted answers
Frankx
Hi
@gawws
I think your best "option" is to fix the "opening balance" which you are indicating Quicken incorrectly changed.
In short - there is no rational explanation for an opening balance to be changed in an accounting system - with the one potential explanation of "the opening balance was FLAT OUT WRONG". Unfortunately, in its efforts to make everything work out in the short-cut way, the latest versions of this application have thrown aside the sacrosanct don't mess with the opening balance concept and have replaced it with the "Let's just try to get the current balance to what we think it should be".
Nevertheless, if you are uninclined to go through the process of determining what transactions were "missed" or "incorrectly reported" in the interval between Sun Trust's transactions and the new Truist account, what Quicken has done is to let you move forward without looking back. And, while I personally don't believe in that approach, I understand that it is at times necessary.
Frankx
All comments
Frankx
Hi
@gawws
Frankx
gawws
Thanks for the response. On one of the affected accounts, I simply set the opening balance back to zero. I performed a reconciliation and that seems to have resolved the issue. Yet as you stated above, the fact that Quicken modified it is very concerning.
iamtherepoman
FWIW, I've had the same issue multiple times on my Citibank accounts, most recently today. Seems to be a Quicken issue and not bank specific. And yes, set the opening balance back to 0
GA Hiker
I have also had the same issue multiple times on my Citibank accounts, most recently today. Each time I have changed to opening balance back to zero which fixes the problem, temporarily. Annoying!
gawws
Just happened again when attempting to reconcile the December statement from SunTrust/Truist. There's no excuse for this. The code should lock all existing records during the update process. I have almost lost all faith in the Quicken development team.
gawws
Quicken continues to modify my opening balance when I "Reset Account", which I have to do periodically when the update function ceases to work. Integrity issues continue.
gawws
Still no solution 1.5 years later. I have a case number and a promise of a bug fix but still nothing.
Quick Links
All Categories
Recent Discussions
Activity
My Bookmarks
My Discussions
My Drafts
Unanswered
Best Of
