Community Homepage
Discussions
Quicken for Mac
Quicken Lifehub
Quicken Mobile
Quicken on the Web
Quicken for Windows
Support
Quicken Classic
Quicken Simplifi
Getting Started
Community Training FAQs
Using and Improving the Community
Connect and Engage
Announcements & Alerts
Announcements
Alerts, Online Banking & Known Product Issues
Product Ideas
Beta
Home
Quicken Classic for Windows
Investing (Windows)
Fix problem with window for entering investment transactions?
mvwabc
When entering an investment transaction, the upper left portion of the screen blanks out after selecting the security name. How do I fix?
Find more posts tagged with
Accepted answers
mvwabc
I just received an update for Quicken that said it was fixing lots of bugs. After installing the update, I cannot reproduce the error I was experiencing. My version of Quicken is now:
Quicken – Deluxe, Year: 2020, Version: R24.11, Build: 27.1.24.11
I did not contact Quicken Support, but looks like they either already knew about problem or it got fixed when they fixed another bug.
All comments
mvwabc
Attached is a picture of the window showing problem.
Rocket J Squirrel
That's a new one. Tell us your Quicken version & year, operating system version, and all that basic info.
What happens if you open Help by clicking the ? at the bottom left corner of the dialog and then close the help? The Help window by default should obscure the investment dialog. Does closing the Help window cause the dialog to repaint properly?
What happens if you drag the Buy transaction dialog around the screen? Does the whiteness move along with the dialog or stay where it is on screen, allowing the dialog to "move out from under" the whiteness?
mvwabc
Quicken – Deluxe, Year: 2020, Version: R23.21, Build: 27.1.23.21
OS Name: Microsoft Windows 10 Home, Version: 10.0.18363 Build 18363
System Manufacturer: HP, System Model: HP Laptop 14-dq1xxx, System Type: x64-based PC
Opening and closing help does nothing to the window. Blank space stays same.
When moving the window around, the blank space follows the window in same spot.
Rocket J Squirrel
Thanks for running those tests. I have seen randomly appearing white areas on my own machine, but the whiteness did not follow any programs around the screen, indicating it wasn't the program's fault. So in this case we can probably surmise that this is a Quicken issue.
Never having seen this exact issue before, all I can suggest is to follow the usual troubleshooting steps.
Uninstall Quicken.
Reboot windows.
Reinstall Quicken, allowing it to update to current release.
Still not working? Try running the
Mondo patch
mvwabc
Some information that I did not previously share is that the problem does not always occur when selecting a security. So, I went back and tested various securities. At first I thought it might be the length of the security entry, but this did not prove out. My best guess is that it has to do with the way the security is entered into the box. If I type in part of the name and select the entry from list, then the problem occurs, but not for every security.
I am using subscription Quicken, so everything should be current. I understand your suggestion about reloading, but don’t think that is the answer. I believe this is a program bug. Hopefully, someone from Quicken is monitoring the community and will look in to this problem.
I did find a kind of squirrelly (pardon the pun) work around for the problem. If you select the clear button, it will show the entry fields only behind the blanked out area. See attached.
NotACPA
If this were a program bug ... why are other's not experiencing it? Why did
@Rocket J Squirrel
comment "That's a new one"?
We've never seen this before ... and no one can reproduce EXACTLY what you're showing.
That leads to the strong suspicion that it's something specific to your Q data file or your PC.
You might have NOT a bug ... but rather a corrupted program installation, which the Subscription updates can't fix.
Reinstall!
mvwabc
I uninstalled Quicken, rebooted and reinstalled Quicken. The problem was NOT fixed.
NotACPA
Contact Q Support. Your options are at the bottom of this webpage:
https://www.quicken.com/support#windows
mvwabc
Quick Links
All Categories
Recent Discussions
Activity
My Bookmarks
My Discussions
My Drafts
Unanswered
Best Of
